Throttle body and PCV connections
I started with a junkyard 2000 LM7 5.3L. It has been machined and rebuilt. I swapped on the LS6 valley PCV pan and an LS6 intake. I followed the instructions I found for swapping to that PCV system except my passenger valve cover did not have the hose port on the rear to cap off. I did plug the hole on the Drivers side rear valve cover. The front of the passenger side valve cover had a nipple for a vent and that is going to the nipple on top of my throttle body. I think thats all right.. Right?
I used the throttle body that came with my LS6 intake. Supposedly it was a 2002 Corvette Z06 intake but I don't know for sure. I do know its LS6 not LS1. That throttle body did not have the throttle position sensor or the IAC sensor on it. I installed the ones from my LM7's throttle body. According to GMPartsDirect.com the sensors are not the same from truck to corvette. They look identical and the throttle bodys look pretty much the same. Will these sensors still work? Or do I need to buy corvette sensors to match the throttle body? The truck throttle body is in really bad shape so thats why I used the corvette one I had. Am I ok on sensors?
Lastly, I am under the assumption that the skinny tubes on the bottom of the throttle body are for the steam line to pass though. Mine are clogged on both throttle bodys so I was just going to bypass it and take the steam line straight to the radiator. I'm pretty sure thats ok but since I am asking.... is it ok?
I think thats all I am unsure on or want reassurance on before I try and start this motor. Thanks
