What’s the deal with this starter??
Old Jul 24, 2020 | 03:41 PM
SHINER's Avatar
Default What’s the deal with this starter??
70 Chevelle
New 6.0 build, LS7 crank, 4.030, Heads, Cam, LSA blower, 4L80- everything is new.
New Starter is ACDelco 3371131
New flywheel is ATP Z-270 14” 168 tooth
using ARP bolts
im not using shims but the bendix is engaging and turnning the motor over but it is making a terrible intermittent sound. I recorded it and you can see shavings, no teeth are broken. What should I do?
is it uncommon to need shins?
Old Jul 25, 2020 | 06:38 AM
SHINER's Avatar
Nobody has a comment? I bet if this was a thread about Meguiars Wax id get a 100 comments within an hour.
Old Jul 25, 2020 | 10:47 AM
It just MIGHT be possible nobody has encountered this issue before.
Keep your shirt on....
Old Jul 26, 2020 | 05:17 PM
I’d throw a shim at it and try it again. Easy peasy...
Old Jul 27, 2020 | 02:11 AM
Twin_Turbo's Avatar
Yup try 1 shim. It's a little tight it seems in 1 spot
Old Jul 27, 2020 | 12:03 PM
themealonwheels's Avatar
I had to shim a new ls3 starter on my ls3 crate motor for my belair. Baffled me, i thought we were past this. But can't argue with the results.
Old Aug 3, 2020 | 07:14 PM
SHINER's Avatar
1mm shim + 1/32" shim fixed the issue
Old Aug 6, 2020 | 09:56 PM
Awesome. Thanks for updating. Until we have no more internal combustion engines left on the planet, a GM small block will always require a starter shim from time to time.
 Michael S. Palmer
