Hi ram on a 5.3
Old Sep 3, 2020 | 08:59 PM
Jl8806's Avatar
Default Hi ram on a 5.3
I think I might've messed up, but they didn't have any of the Mid-Ram intakes in stock anywhere so I finally found this one at Summit Racing:
https://www.holley.com/products/inta...parts/820032-1
I've got a Holley Terminator X ECU & harness, 92mm Holley TB and some Holley 36 lb/hr injectors. Truck is a 5.3 4x4 with a 5 speed manual. Am I going to be sick of the way it runs? The engine is a new (Jasper remanufactured). I noticed the cast intakes said recommended for engines from 6.0-7.0L, but I saw no mention of that on this fabricated intake. Thanks for any help or recommendations.
Old Sep 5, 2020 | 10:35 AM
wannafbody's Avatar
The high ram has longer runners than the mid ram so that's good. Still a TBSS intake would probably be best.
Old Sep 5, 2020 | 10:30 PM
AwesomeAuto's Avatar
The mid-ram intake is a joke when it comes to power. The stock truck intake will outperform it.
The Holley Hi-Ram and Holley Sniper intakes will get outperformed by the stock truck intake unless you're revving the 5.3 over 6800 RPM.
Old Sep 10, 2020 | 01:15 PM
Summitracing's Avatar
LS1Tech Sponsor
That would be less than desirable on a 5.3 in a truck unless this is a high revving race truck. Like others stated you'd be better off with a stock truck intake or the TBSS intake.
__________________
800-230-3030
www.SummitRacing.com
