Overpowering smell of fuel coming from engine.
No obvious fuel leaking anywhere. Car does not have a fuel tank trap door.
Also, the car battery was disconnected before we removed the pcv lines. Car idles at 550 rpm now - did not try driving it yet. Any thoughts?
you either pinched an o-ring (probably at the rail) or cracked the factory line from the tubing to the rail. No need to run it, just have someone cycle the key to on while someone watches under the hood. Pretty simple. If it's none of those, maybe you touched fuel evap lines instead of pcv on mistake?
now that I think of it, if you took the rails off the injectors, you need to change those upper o-rings. They're 19 years old, due for a change when the rail is off
That caused the following codes to be thrown:
P0300
P0355
P0358
P0452
P1637
All cleared once pcm basket was shifted lower. Hope this helps someone else.
