Fuse Block
Old Oct 21, 2020 | 08:43 PM
86K5lq9's Avatar
Default Fuse Block
Hey guys wiring up my LQ9 engine fuse block for a swap into my 86 K5 Blazer. Looking for some help on figuring out where things go to get power. I know all pinks run off ignition. The rest of them is what I’m having a problem with so let me start with what I believe to be correct. •starter solenoid- hot during crank
•Crank voltage- hot during crank and run, goes to ignition relay
•stop lamp- goes to brake light switch, hot when brakes are applied
•Starter enable relay control- goes to starter relay
• Battery Positive- straight to battery
• Park, Neutral start switch- hot with ignition
• stop lamp- goes to brake light switch, hot when brakes are applied
Now what I need to know
•fuel pump relay- is this to supply power through relay or to turn relay on?
•Trailer back up lamp? Power from column shifter? Relay between?
• Park neutral position switch-?
•TCC brake switch-?
•Cruise control release, I imagine signal from brake pedal? If so how?
•Ground- why is there a ground running into fuse block? What for?
Old Oct 28, 2020 | 05:29 PM
00pooterSS's Avatar
That is to trigger the relay, the power side (that runs through the relay and out to the pump) is from a fuse in the fuse box.
Not sure
Uh not 100% sure what side of what we're talking about, but it should get power with key on only
•TCC brake switch-?
Gets a signal to pcm from brake switch
Brake pedal
Not sure
That's what I can add
