Ls1 with fast mani oil issue
Old Oct 24, 2020 | 10:11 AM
Chonda's Avatar
Default Ls1 with fast mani oil issue
I just did a head cam intake built and I’m finding oil on my intake near the bolts and injectors. The valve covers are drying I read some stuff where people put some sealant on the threads. Anyone have any suggestions or tips. Also catch cans, vented ones in the valve covers or sealed one in line with the ls6 pcv system?
Old Oct 24, 2020 | 06:53 PM
Chonda's Avatar
Well if the heads are CNC's to the point that the rocker arm bosses have been removed in the intake runners then you'll need to run thread sealant on the threads of the intake rocker arm bolts. As for PCV systems as long as your stock then I'd keep the stock PCV system intact. I would recommend adding a sealed catch can to help cutdown on the amount of oil the intake manifold pulls into the engine. I'm currently venting to atmosphere on the 427 with a single breather can connected to both valve covers via 10AN lines. I did have to open up the size of the valve covers for the 10AN lines but its been working. I should probably go one can per side but its just as easy to replace the fill cap with a breather style fill cap.
I have PRC as cast 15 degree heads. So I need to pull the covers and sealant on my rocker arm bolts? And what sealant? Also do I need to put anything one the intake mani bolts?
