PCV Questions for my build
I have a 2006 5.3 L33 with a later model TBSS intake with an aftermarket 92mm throttle body. What is the best way to hook up the pcv system to avoid vacuum leaks. I also noticed that while the vacuum port on the throttle body is there, it is blocked off with a plug. Where can I get the little elbow to hook a hose to this vacuum port? Thanks in advance for any help or advice!
