Starter to Flywheel 6.0
I contacted summit asking what starter do I need I was told a Gen 1 with a shim ha no such luck not even close I can't even lineup one bolt hole. Anyone know what starter setup I need any and all is welcomed.Attached the 4L80 to a 4.8 which I then replaced with a 6.0. (Replacing the 4L60)
Used the stock flywheel and the stock starter.
I got the 4L80, converter, and lines from a mid 2000 truck. I did need a spacer for the tq/flywheel.
can you confirm what year your tranny is from?
Sorry to hear about the problems you're having with the starter not matching up. We've sent you a private message so we can dive into this further.
The early version had a longer crank, at the rear. Something around .400", a little over 3/8".
https://help.summitracing.com/app/an...bolt-up-my-old
