Help 2005 gto tach not working
Tachometer Inaccurate or Inoperative
Step
Action
Value(s)
Yes
No
Schematic Reference: Instrument Cluster Schematics
1
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
2
Install a scan tool.
Start the engine.
Observe the Engine Speed parameter in the powertrain control module (PCM) Data 1 data list.
Does the Engine Speed parameter match the tachometer display?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
3
Replace the instrument panel cluster (IPC). Refer to Instrument Cluster Replacement .
Did you complete the replacement?
Go to Step 4
4
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Double check all grounds are clean and tight.
Instrument cluster = ALL the stepper motors and the driver electronics, in one big assembly
No sense in changing the whole cluster if only one stepper motor is bad.
