Tbss intake question
Old Apr 3, 2021 | 02:20 PM
Cheyenne95's Avatar
Default Tbss intake question
Is there way to retain egr with the l92 or tbss intake by modifying the intake?
Old Apr 3, 2021 | 04:29 PM
Those are both Gen IV intakes, the L92 from a 6.2 and being rectangular port, and the TBSS from a LS2 6.0. Any reason for dong this? Later engines did not use EGR. Only the LS1 ever had it.
Old Apr 3, 2021 | 08:04 PM
Cheyenne95's Avatar
my 02 sierra 2500 has it kinda wanted to keep it smog legal but I think some came without so I might be able to get away with removing it
Old Apr 3, 2021 | 09:44 PM
So you have the LQ4?
Old Apr 3, 2021 | 10:43 PM
Cheyenne95's Avatar
Currently
Old Apr 3, 2021 | 11:22 PM
Can't use the stock intake? It flows almost as well as the TBSS.
Old Apr 4, 2021 | 12:09 AM
Cheyenne95's Avatar
I'm currently building 427 so I'm swapping the 6l out but It should work
Old Apr 4, 2021 | 12:25 AM
What sort of emission testing is done in your state (which one?).
If they sniff, you might have a problem. A 427 will test way different than the old LQ4.
If it's visual, just keep the outside stock, and use a smooth cam.
If, like here in California, they hookup to your OBDII port, just make sure there are no codes showing. We also do visual besides the OBDII scan.
 Michael S. Palmer
Old Apr 4, 2021 | 12:35 AM
Cheyenne95's Avatar
it's a sniffer but I plan on getting a cam with negative overlap to pass
Old Apr 4, 2021 | 12:43 AM
Which state are you in?
Old Apr 4, 2021 | 12:44 AM
Cheyenne95's Avatar
Utah 1/2 tons get obd2 3/4 tons the 2 speed sniffer
