Exhaust leak/Valvetrain noise?
Old Jul 3, 2021 | 08:12 PM
mrsaturn110's Avatar
Default Exhaust leak/Valvetrain noise?
Trying to identify a noise that I suspect is an exhaust leak but also seems like could be top end related. At idle when the car is warm I can only hear it from under the car, but it sounds like it is in front of the header on the drivers side. At first I felt a small leak by the collector, but I cant imagine it's enough to make the noise that it is. Speed engineering 1 3/4 headers and Y pipe, installed about a year ago, and the noise is relatively new. Don't remember it happening before this season. I'm considering replacing the small band clamps with Jegs lap joint clamps at all the slip unions. Any idea what the issue is would be greatly appreciated. The video linked is a clip of the sound.
Old Jul 16, 2021 | 08:06 AM
Originally Posted by mrsaturn110
Trying to identify a noise that I suspect is an exhaust leak but also seems like could be top end related. At idle when the car is warm I can only hear it from under the car, but it sounds like it is in front of the header on the drivers side. At first I felt a small leak by the collector, but I cant imagine it's enough to make the noise that it is. Speed engineering 1 3/4 headers and Y pipe, installed about a year ago, and the noise is relatively new. Don't remember it happening before this season. I'm considering replacing the small band clamps with Jegs lap joint clamps at all the slip unions. Any idea what the issue is would be greatly appreciated. The video linked is a clip of the sound. https://youtu.be/eUGfCsK5zdo
This ended up being a blown exhaust manifold gasket. I do have leaks at the Y pipe still, but it is substantially quieter after replacing the driver side gasket.
Old Jul 16, 2021 | 08:12 AM
shakenfake's Avatar
Damn that is loud! Did yours get louder getting in the freeway right after a cold start? That's how mine is on my Silverado. I have the gaskets just waiting on the headers to replace my exhaust manifolds....
Old Jul 16, 2021 | 08:19 AM
At WOT it was really bad. After warming up, I'm assuming the heads/exhaust expanded enough to help seal the gap. Hindsight 2020, don't get bored hanging out with your tuner and decide to run a burble tune on your car for half an hour!
Old Jul 16, 2021 | 08:21 AM
shakenfake's Avatar
Yeah that is what I think too. I have left this exhaust leak for like 2 months now and won't be doing it for another month. God damn am I lazy ROFL
I could always swap gaskets but I got a cam and some low tier heads so might as well slap some headers and call it a day
Old Jul 16, 2021 | 08:28 AM
I'd probably wait for the headers too if I was you. I was becoming concerned something in the top end of my car was about to let loose because it kept getting louder as the gasket was getting worse. Thankfully its not a hard fix, just one of those time consuming jobs -- especially when you find out 2 of your spark plugs are cross threaded during reassembly.
Old Jul 16, 2021 | 08:42 PM
wannafbody's Avatar
Use MLS type exhaust gaskets.
