Best Exhaust Mufflers
I currently have a spin tech muffler. It's just a little bit too "aggressive" for my aging ears. I'd like a "deep and mellow" exhaust note. I really don't mind an exhaust that is a little bit on the loud side, but I want to as little drone and rasp as possible. I was possible thinking about a set up like the borla cat back where I can possibly install a boost actuated exhaust valve on one side to bypass the muffler, but I don't think I'd enjoy the borla sound.
When I put on Thorley mid-length headers I used the gas pack straight threw muffler that came with the headers. It had a bad drone so I put in a resonator in the center pipe which did nothing. I put the stock muffler back and ran that for years. Last year I replaced the stocker with Dynomax Performance -super turbo oval. It is louder than stock but with no drone.
It is one that David Vizard said he had a hand in developing. Summit part number WLK-17792, 3" pipe diameter. I first got a longer "Dodge" one but that had a flat inside with a extra chamber that did not have the smooth curved exhaust routing.
Going from 2.75" pipe dia. to 3.0" dia." is good.
Hope that helps
Hope that helps
With money saved from going TSPs instead of ARs, I would go with a 4 inch Mufflex exhaust, and a Magnaflow Muffler.
This would be most efficient and sound good but not obnoxious.
I can not hear any noise when I am off the throttle. There is a low level when on the throttle but nothing too loud.
Never had any real drone issues.. at least no worse than other performance mufflers.
