Belt tensioner
Old Apr 2, 2022 | 09:48 AM
Kurtknarr's Avatar
Default Belt tensioner
Does anyone have a part number to a better belt tensioner? My 2004 5.3 stroker keeps throwing the belt and I’d really like to stay away from a manual tensioner if possible
Old Apr 2, 2022 | 10:13 AM
If you find something that works, please post up about it here. After a couple thrown belts and a heavily shredded belt on my 434, I went manual and never looked back. Set it and forget it. I’m running Holley (C6 corvette) accessories for what it’s worth. The OEM tensioners aren’t designed to handle a quick revving build.
Old Apr 2, 2022 | 10:17 AM
Z28SteveA4's Avatar
Katech manual tensioner over here like chevelle said set it and done!
Old Apr 2, 2022 | 10:18 AM
Kurtknarr's Avatar
In my mind I would think that the manual one would add extra stress to the pulleys, or strength the belt sooner
Old Apr 2, 2022 | 10:23 AM
Not the case. If anything, mine is set with less tension to the belt itself, than the OEM one. My belt isn’t loose by any means, but it’s just not quite as “tensioned” as the spring loaded tensioner had it.
Old Apr 2, 2022 | 10:26 AM
Kurtknarr's Avatar
i will try to find the right one for my application
Old Apr 2, 2022 | 10:27 AM
What accessories are you running?
Old Apr 2, 2022 | 10:46 AM
Kurtknarr's Avatar
Alternator water pump tensioner idler crank
 Michael S. Palmer
Old Apr 2, 2022 | 11:46 AM
I wasn’t clear with the question…are you running F-body, truck, corvette, etc accessories? The manual tensioners are built for specific vehicles.
Old Apr 2, 2022 | 11:48 AM
Kurtknarr's Avatar
im running the 04 Silverado truck bracket
Old Apr 2, 2022 | 12:00 PM
This might work. It has the truck spacing, but I’m not sure what’s on your pass side cylinder head…
https://www.summitracing.com/parts/i...iABEgJPOvD_BwE
Old Apr 2, 2022 | 01:37 PM
QwkTrip's Avatar
I was concerned about that too so I spoke to my Dayco belt engineer (I have access to people like that) and he assured me the manual tensioner is fine. The belt does need to be tightened twice though, once upon install and then again after about 5-10 minutes of run time. The reason why is because the belt tension will relax as the belt ribs sink into the pulley grooves (it's not because of belt stretch). The second adjustment gets the belt back to proper tension and it will stay good for a long time.
I threw belts in rapid decel. No more problems since installing a manual tensioner.
I also switched to those gator belts or whatever they're called. Seems people report those belts don't get thrown quite as easy. Don't know if that is true but it's a nice belt either way.
Old Apr 2, 2022 | 02:35 PM
Kurtknarr's Avatar
thank you sir for your input I’ll get one ordered up
Old Apr 2, 2022 | 07:26 PM
LilJayV10's Avatar
FWIW, I've been running the Katech manual tensioner for the past 12 years or so. Car sees 7 grand+ and I've never, ever had a problem.
Make sure you are running a good belt likes Gates. Cheaper belts stretch, sometimes rather quickly.
Old Apr 5, 2022 | 07:07 AM
Efx's Avatar
Efx
I switched to ACDelco 12569301 (LS2 belt tensioner). It has a taller lip vs LS1/LS6 tensioner.
A lot of corvette track guys stopped throwing belts at the track with LS2 tensioner.
Old Apr 5, 2022 | 08:22 AM
01CamaroSSTx's Avatar
LS1 accessory and A/C belt tensioners on the 01 which has an ATI Super Damper. I've yet to throw a belt but I did have to buy a slightly smaller accessory belt than the stock one.
