Throttle body problems
Old Jun 4, 2022 | 01:55 AM
Z28 Jay's Avatar
Default Throttle body problems
I have a 102 throttle body i keep getting code p0122 stating that the gas pedal/ throttle body position sensor circuit a is low and I replaced the sensor 5 times and the tps harness and i still get the code after a good launch. Any help with this problem? Ls1 engine
Old Jun 4, 2022 | 10:33 AM
You can remove extra posts by going to the bottom right of the post and hitting the "edit" button and going from there
Old Jun 5, 2022 | 09:27 PM
jetech's Avatar
Veteran: Air Force
Does it only happen when you accelerate hard?
Old Jun 11, 2022 | 10:47 AM
1998 t/a's Avatar
What other modifications do you have and has it been tuned?
Old Jun 11, 2022 | 12:33 PM
AgFormula02's Avatar
Are you able to check TPS voltage at zero and 100 percent?
Old Jun 12, 2022 | 02:34 PM
LilJayV10's Avatar
What vehicle? What PCM? What T/B?
Is it tuned? Do you have any logs?
People, you have to provide information when asking a question. We aren't mind readers.
Old Jun 12, 2022 | 03:18 PM
Kjduvall's Avatar
If it's a cheap Chinese TB, your just going to have nothing but trouble with it. I've dealt with two ove them and swear never again will I do that. Switched to a Nick Williams and was trouble free after that. The first one full of codes, never could get the tps dialed in and drivability was crap.
Old Jun 15, 2022 | 07:48 PM
chevybayboy's Avatar
I'm having this same issue as we speak stock pcm it's kinda tuned go back tomorrow for a tune. It's reading 5v. At 0 it reads .73 at 100 it reads 4.5 this is with a fast tb I had a cheap one a Fitech and a fast still the same code
 Michael S. Palmer
Old Jun 20, 2022 | 12:47 PM
1998 t/a's Avatar
tuning cleaned all the idle issues up
Old Jun 20, 2022 | 03:57 PM
For the OP? How do we know?
Old Jun 21, 2022 | 07:57 AM
1998 t/a's Avatar
I was having same issues as op, sorry forgot to provide context.
I tried IAC, TPS, Vacuum lines nothing cleaned it up and fixed it for good. took it to get tuned regardless and i asked about it and they said "yeah it was all in the original mail order tune" got it squared away car runs great.
