valve cover torque specs
Old Jun 23, 2022 | 08:13 AM
95maroz28's Avatar
Default valve cover torque specs
How much do you torque ls1 valve covers? 8.3 ftlbs? i read 12nm. Also on new fel pro gaskets with the new rubber grommets for the center bolts you install them dry correct no oil lube is needed? I read somewhere about cheap ones cracking or splitting. The new rubber grommets slipped right over the center bolts. I was replacing the passenger side gasket as it had started leaking at the front corner after having removed the valve cover 3-4 times for c5 header install, cam install. fel pro gaskets are good correct and 8.3 ft lbs? They dont need to settle and retorque?
Old Jun 23, 2022 | 06:41 PM
jetech's Avatar
Veteran: Air Force
106 inlbs. = 8.8ftlbs. Retorque if you like. The manual doesn't state to retorque though. I use Hylomar on the seals.
Old Jul 6, 2022 | 03:27 PM
95maroz28's Avatar
I used new fel pro seals from amazon. Yes i did 9ftlbs with the torque wrench. The old one was leaking at the front passenger corner onto the header. I had removed them 3-4 times to install c5 headers, a cam, then to swap stock pushrods to tsp 7.4". They seem like they work great easy to install the seals fit right perfectly into the valve covers and center bolts have new solid rubber grommets. Not sure if you're supposed to coat the valve cover bolt grommets in oil but got them on and installed.
