LM7 fuel rail question
Old Aug 19, 2022 | 08:10 AM
Budco's Avatar
Default LM7 fuel rail question
I'm building a 2002 LM7 and using an adjustable fuel pressure regulator on the return side. I using the factory fuel rails and trying to find out what to do with the factory regulator. Is there a plug for the factory regulator or what do I need to do with it ?
thanks, Bud
Old Aug 20, 2022 | 08:37 PM
jetech's Avatar
Veteran: Air Force
I think you should be able to remove the small o'ring and enlarge the hole the o'ring seals against in the fuel rail. That should allow the fuel to flow and you would be using the regulator as a plug.
