Plug wires for headers
Old Aug 23, 2022 | 07:26 AM
Jake Wade's Avatar
Default Plug wires for headers
Would like recommendations on plug wires for use with speed engineering long tube headers.
This is a 2006 Silverado 1500 with the 5.3.
I hear 45 degree boots is what I need.
I saw where speed engineering has their own line of plug wires with correct boots. Anyone have feedback on these?
Old Aug 23, 2022 | 08:44 AM
99 Black Bird T/A's Avatar
In my experience a new set of stock AC Delco spark plug wires work great. They even have a metal heat shield that helps protect the wire from heat.
Have also had good experiences with MSD's plug wires.
Old Aug 23, 2022 | 09:31 AM
B52bombardier1's Avatar
To the note above about using stock AC Delco plug wires, I also added the high temperature cloth, heat resistant tubes of plug wire protection to each wire. They are available on Ebay for short money in a variety of colors. Using some needle nose pliers, I pulled the metal ring out of each cloth tube to gain some slack in the cloth so that each tube would sit further down around each metal AC Delco spark plug protecting tube.
Now my Blackheart headers can't harm my plug wires.
Rick
Old Aug 23, 2022 | 09:51 AM
Jake Wade's Avatar
Mmm, interesting. I thought the OEM straight boots would contact the header tubes.
Old Aug 24, 2022 | 12:57 AM
RevGTO's Avatar
Pontiacerator
Correct. MSD's with the bendable boots is what you want to clear the header primaries.
Old Aug 25, 2022 | 08:41 AM
grubinski's Avatar
Last time I went to the dyno, I had several wires that had burned through the fiberglass sleeves I had over them. The dyno guy said he wasn’t a fan of those, since in his opinion they just hide damage, they don’t prevent it.
He recommended the MSD ceramic boot wires.
Old Aug 26, 2022 | 03:55 PM
LilJayV10's Avatar
It just depends on what brand. I've installed some that can use the stock wires/heat shields, other I had to use the MSD wires.
Old Aug 28, 2022 | 08:26 AM
1bdbrd's Avatar
I ran my Silverado for years ac delco stock replacement wires with TSP headers with no issues. Just turn the boots on the coil end to pull the wires away from the primaries. Never burned through.
 Michael S. Palmer
Old Aug 28, 2022 | 09:24 AM
rednari2's Avatar
This! the OE wires are fine, and can be removed without breaking the ends.
Old Sep 1, 2022 | 11:44 PM
Undertow74's Avatar
I run the granatelli wires with the heat socks. They are actually a really nice set of wires and clearance headers perfectly. Only granatelli thing i use
Old Sep 2, 2022 | 10:18 AM
99Silver6.0's Avatar
Been running the Hinson 45° plug wires for a little over 4 years. They dont touch any primaries and havent burned a single one. I threw my MSD's in the trash because they were an absolute bitch to engage/disengage on the coil packs. That and one plug boot ripped off.
Old Sep 2, 2022 | 10:25 AM
rednari2's Avatar
Good choice but expensive. But, they have a lifetime warranty.
Old Sep 2, 2022 | 10:28 AM
rednari2's Avatar
Yes, plug boot tear offs are common with a number of after market sets. The Delcos will eventually tear off, but only after years of on and off removal.
Old Sep 2, 2022 | 11:19 AM
My MSD's did it after 6 months.
