vacuum pump install
Old Sep 30, 2022 | 07:06 PM
Floorman279's Avatar
Default vacuum pump install
got a gz motorsports kit. have crower rockers with LME valve covers. running an msd intake so i assume the only place i can pull from is the valve cover. only thing is i need baffeling if im pulling from the valve cover correct? if so there isnt enough room under the lme covers to do that so ill probably have to get taller covers
Old Oct 2, 2022 | 12:37 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I tried one of those several years back, and could not get the pulleys to properly line up with the supplied brackets. The details are fuzzy all these years later, but I ended up never using it. Sorry to be of no help.
Old Oct 2, 2022 | 12:19 PM
all good. we are goona fabricate out own bracket. my guy said thats the easiest way and maybe it is because of having similar issues like you were having.
Old Oct 5, 2022 | 09:23 PM
Rob383's Avatar
they have a baffle that goes on top of your valve cover.
Old Oct 6, 2022 | 09:23 PM
JimMueller's Avatar
Which Crower rocker arms PN? Happen to know the weight over the nose, or can you measure it? Don't ask me how to do so accurately I'm just curious how they compare to OEM & Tony's 10mm rockers.
