Bolt length to head for engine removal
Old Dec 13, 2022 | 03:24 PM
808_ss's Avatar
Default Bolt length to head for engine removal
Pulling motor from top. How long do my bolts need to be to attach my hoist to the cylinder heads? I know the threads are m10x1.5mm but how long should it be?
Old Dec 14, 2022 | 06:48 PM
jetech's Avatar
Veteran: Air Force
read...Be safe
Old Dec 15, 2022 | 12:56 PM
91 Z28's Avatar
Long enough to tighten down. I wanna say I used 1.25" long bolts when I put my engine into my car. I put a washer on the bolt and stuck it they the chain and tightened it down
Old Dec 15, 2022 | 12:57 PM
91 Z28's Avatar
Originally Posted by jetech
Old Dec 15, 2022 | 03:40 PM
sjsingle1's Avatar
the plate i have for front head mounted engine pulling uses 3 bolts...plenty strong ....if it used only 1 bolt i would be worried
Old Dec 18, 2022 | 04:19 PM
LS1 TJ's Avatar
I use four 10.9 metric bolts, two per head front and back. I also use a engine leveler. It makes adjusting the engine and trans angle so much easier.
