Oil Cooler Block Off Gasket
Installing a new Oil cooler block off plate gasket, do these metal crush gaskets go on dry, or would you guys suggest a thin layer of RTV on both sides in case mating surfaces arent 100% true being 20yrs old.
More important is, verify that your blockoff isn't "bent", or that the bolt holes aren't already stripped. From overtightened bolts, in either case.
You can largely bulletproof the installation if you get a new blockoff, and Heli-Coil the bolt holes; then don't tighten past maybe 16-18 ft-lbs on the bolt. Stop at 15 to be safe.
