LS3 injectors on Fast 102
Old Feb 28, 2023 | 08:56 PM
avchz's Avatar
Default LS3 injectors on Fast 102
Recently bought a FAST 102 intake for my FBO cammed LS1 running on 91. Im planning on using a LS3 fuel rail with LS3 injectors that i have laying around. My question is, are LS3 injectors sufficient enough fueling wise for this set up? thanks
Stock bottom end LS1, TSP 232/234.600"/.600" 112 LSA, 1 7/8s headers, 243 Heads , 10.5.1 CR, 2.5 dual exhaust, x pipe, 6 speed manual, 3.73 12-bolt, 1967 Camaro
Old Feb 28, 2023 | 09:14 PM
SAPPER's Avatar
Yes. They are rated at 39# @58psi. They will hold you for everything you have and more...until you boost.
My sons has 42# on a NA 408 making @ 550rwhp and on the dyno and his duty cycles were about 70-75% @ 7000 rpm
