Throttle body without vent tube?
The rest of the system needs to stay exactly as it came. Especially in a car with a MAF. Dirty crankcase air that the PCV sucks into the intake passes through the catch can, and liquid oil and whatnot is allowed to precipitate out of it, just like water does in the dryer in a compressed air system.
Not sure about "vent". Never seen or heard of any such in one of these systems.
There's a line off the TB or intake (varies from one system to another) that's BEHIND the throttle blades such that it's exposed to intake vacuum and has the PCV valve at the other end (which is the line that the catch can should be installed in), and another off the TB that originates BEFORE the throttles (atmospheric pressure, i.e. not vacuum) but BEHIND the MAF that brings clean filtered "makeup" air into the crankcase to replace what gets drawn out through the PCV. AFAIK the 1st one is on the driver's side VC (unless you have the LS6 valley cover and associated setup) and the other on the pass side. Any other arrangement won't work since you have a MAF. So I'm guessing that whatever your question is, the answer is "no".
As built, the PCV (driver's side VC, or valley cover sometimes) draws vapors OUT of the crankcase and INTO the intake to be burned, by way of vacuum; and fresh clean filtered "makeup" air at atmospheric pressure, that's been through the MAF and thus been metered so that the ECM knows it's there and will supply fuel for it accordingly, is supplied into the pass side VC.
The catch can belongs in the PCV line (the one with vacuum on it) where it can trap liquids that would otherwise be drawn into the intake. It doesn't alter anything about how the PCV system works. It causes no change in the fundamental operation of the system, any more than putting a dryer in line with your paint gun or other air tools, makes your air compressor work any differently.
Brand of intake doesn't matter. The PCV system still works the same way.
Only exception to this is, if you're using forced induction; since then, the intake sometimes has pressure in it instead of vacuum, which obviously would "reverse" everything. Obviously a PCV system based on vacuum can't possibly work right in that situation. You don't mention any of that so I'm guessing that doesn't apply.
Not sure about "explanation" or "read" or "reverses" or any of that. My guess is that you misunderstood something. I'm glad I was able to help set you straight.
