LS6 valley cover install?
Old Sep 11, 2023 | 03:07 PM
customblackbird's Avatar
Default LS6 valley cover install?
I picked up a new LS6 valley cover in the hopes of swapping to some really nice billet specialty valve covers which have no PCV ports or barbs etc. I was hoping to run the LS6 valley cover by itself to either a catch can or through an oil/air separator that I have currently and plumb into the intake. My 99-03 5.3 currently has air filter in the oil fill cap and the pass valve cover PCV going into a oil/air separator and then into the intake behind the TB. I've heard the new 04+ has the fixed orifice PCV internal in the underside of the valley cover and just needs to be hooked up behind the TB? I always thought the engine needed a fresh air source as the LS6 valley cover would be under continuous vacuum without a filter air source to offset. Unless the blow by is enough that no fresh air is needed.
Does anyone have a diagram on how this gets setup? Also I could install the oil/air separator in the LS6 valley cover outlet and then rough from the separator to the intake behind the TB.
