2002 Camaro SS water pump
Old Oct 20, 2023 | 07:05 PM
surfside88's Avatar
Default 2002 Camaro SS water pump
Can someone please help. I'm so confused reading past comments. I have a 2002 SS motor is apart so i figure just change the water pump since I'm here. Oreilly's gave me two numbers for ACDelco pumps. 251-744 and 252-846. From what i gather from past submission i need 251-744? Is this correct?
Old Oct 20, 2023 | 08:18 PM
jetech's Avatar
Veteran: Air Force
info from another forum
Old Oct 20, 2023 | 08:19 PM
jetech's Avatar
Veteran: Air Force
Both will work for your application. 251-744 is the OEM replacement
Old Oct 20, 2023 | 09:50 PM
surfside88's Avatar
ok so shouldn't need any new thermostat then?
Old Oct 21, 2023 | 03:35 PM
LS1 TJ's Avatar
Shouldn't need a new thermostat but if it's original to your 2002 it's not a bad idea to replace it. I typically get one from NAPA.
Old Oct 21, 2023 | 09:00 PM
RevGTO's Avatar
Pontiacerator
I made this comment recently in another thread, but I went with the OEM 251-744 even though it was $100 more. Reviews indicated that it is the best choice for long life. The previous Dorman unit I installed lasted 10 years and 75k, which is pretty good, but my goal is to do this job as infrequently as possible.
