Header Problem?
Old Jul 27, 2004 | 05:01 PM
cyphur's Avatar
disconnect your battery for 25-30 mins. that way your computer will attempt to relearn the tables. if this doesn't fix it, then you'll prolly just need a slight tune, you may be running rich.
Old Jul 27, 2004 | 05:16 PM
P Mack's Avatar
You need to find out what code it is your throwing, then it will be much easier to troubleshoot. You could have a burnt o2 wire, a messed up o2 extension, dead sensors, etc.
Old Jul 27, 2004 | 05:24 PM
cyphur's Avatar
thought he said he already pulled his codes??
if not....get her on a scanner and pull those bitches and post 'em up...that will smoothe out this process.
Old Jul 27, 2004 | 08:09 PM
Tiger2o69's Avatar
found the problem. the back spark plugs was slighty cracked , so little it wasnt even noticable until i looked really close.
Another problem tho. I am running about the same times on the gtech that i was. I am actually running a bit slower. I know it might not be accurate but it is precise.
Could this be because i need a tune or that i just need some kind of restrictioin considering i am bascially running open headers because im using the lm?
Old Jul 28, 2004 | 12:51 PM
frey51's Avatar
AutoZone is your friend when it comes to codes. They will hook you up and give you a reading for free. Some other parts stores might do the same. Basically, you just need to find out what codes you are throwing. Then you can track down the problem
Fry
