3/8 exhaust bolts
Old Jan 30, 2024 | 03:23 PM
smokeatr23's Avatar
Default 3/8 exhaust bolts
Has anyone tapped exhaust bolt holes for 3/8? Is there enough meat around the holes for that? Would rather do that than helicoil.
Old Jan 30, 2024 | 05:40 PM
wlink14's Avatar
I've done it with success on LS and Volvo engines with factory M8 hardware. 3/8 stainless stuff wont break. Don't go too deep!
Old Feb 2, 2024 | 03:26 PM
LS1 TJ's Avatar
If you go stainless make sure you put "never seize" on the threads. Either a 3/8" bolt or heli-coil you will still have to drill and tap.
Old Feb 2, 2024 | 08:26 PM
smokeatr23's Avatar
Default 3/8 work
Yesterday I drilled and tapped the head for 3/8-16 exhaust bolts and it worked well. I didn't go any deeper than the original holes.
