You are on the right track. You can decide if you want a seperate oil fill or not, that doesn't really matter - strictly preference. Check into the billet breathers like you are talking about - they make one with a PCV built in and one with only the elbow - I think Jegs sells them - they would look nice. If it were me, I would get one each of the billet breathers and put them in the front and use one as the oil fill. Then get braided covering for the hoses to the TB and manifold. You shouldn't need a catch can with those breathers, and you don't need the LS6 valley pan either.
Thanks for the information. Last and final question. If I do it the way you just said, and used the breathers your talking about (I know which ones you mean) then the tube going from the throttle body would go to one of the breathers, the tube coming off of the manifold (which is the pcv itself) goes where? The driver side breather? And thanks again.
Not to confuse you, but I just took another look in Summit and Jegs and here is the best way I can see to do billet breathers with the ones they offer: use a breather with no tubes or PCV on the DS, and use a breather with the PCV in it on the PS with a hose from this breather to the manifold connection (do not put the stock PCV valve in anywhere - use the one in the billet breather instead), and then plug the connection on the TB. This makes it simpler and cleaner because you will only have one hose and not have to run a hose all the way across to the DS. The billet breathers with no tube or PCV would work fine for a fresh air inlet (vice connecting to the TB connection). Make sense?
Here are the part numbers (for the plain one) to help you out: DS use Billet Specialties #20120, PS use Billet Specialties #21120 with a hose to the manifold connection, plug the TB connection with a vacuum cap.
Makes perfect sense, thanks a lot. Thats the information I've been looking for.
