Valve cover gasket thickness options?
Asking because I have Holley's tall covers on Golen heads, and there's a bit of an oil leak on one side. Only noticeable after high RPM, in one little spot. I'm guessing the tolerances stacked up juuust enough...
I can trim down the spacers that support the valve cover if need be, but I'm lazy so I'd like to try thicker gaskets first, if that's a thing that exists. Does it?
Thanks!
I am really hoping for just 1-2mm extra thickness though. Unfortunately I have very little space between the valve cover and alternator.
Will probably shave a bit from the standoffs this weekend.
