PS Pulley Help - Custom spacing needed?
Shaft diameter is push-on 0.66" GM Type 2.
I looked all over and the only company listing dimensions such as this is March and they only have 1 option with this shaft and no dimensions listed. I emailed their tech support and am awaiting a response.
Here's the Holley pulley dimensions . Part No: 97-152 or GM 19421325
And here's a photo depicting the diff between the 2 pumps. Holley on the Right, KRC on the left.
Finally here's what that Pulley looks like on the KRC pump set in the position aligned with the belt. As you can see the shaft is about 0.6" from being fully seated.
