Rookie trying to diagnose backfiring issue
Still sorta new to everything, backfiring only happens on Bank 1, not up to temp.
What’d be your initial thoughts as to the cause
Bad tune, bad gas, bricked o2s, something internal within the valve train?
What would be your guys first step to diagnosing this backfiring?
Would gladly provide more info
https://youtube.com/shorts/SlgCiYtvv2k?si=hInRiX5MsiJ4Fou-
It’s got new MAF and o2s, crank and cam sensors are original with ≈175k in them so I think they could potentially be shot.
I actually took C1 and C3 plugs, wires, and coils, and swapped them but no change so it’s leaving me to believe this is a fuel (injector) problem?
I undid the valve covers, no bent pushrods, all still 22ft lbs, they’re opening and closing.
Whats made me believe it’s an injector problem on C3, is that in the process of richening the fuel trims for the misfire, how is it that C1 has a rather carbon covered plug, but C3 has near none at all?
More or less the brain process I’ve gone thoufh to find this
