ARP crank bolt any good
Old Jul 3, 2024 | 10:37 PM
66OldsLS's Avatar
Default ARP crank bolt any good
Pulling the crank pulley off and already have an ARP bolt. Will the ARP crank bolt work with the factory balancer? The ARP balancer bolt is a little longer than the OEM bolt and I’ve heard about the bolt backing out. Anyone know anything?
Old Jul 4, 2024 | 10:40 AM
91 Z28's Avatar
It'll work just fine the bolt gets torqued to 240 ft/lbs with moly lube. If you're concerned about it backing out use some thread locker. I never used any thread locker on my bolt and haven't had a problem with it backing off
Old Jul 4, 2024 | 11:04 AM
66OldsLS's Avatar
okay, thanks!
