Replacing water pump/thermostat/housing
Read some info on LS1 water pumps being replaced with LS2 pumps, and subsequently requiring different housing and thermostats? If I'm going to replace these 3 items on a stock motor, what is my best course of action?
I do have a Gates 33963 thermostat on hand, which I believe is the standard 186 degree thermostat for the stock LS1 pump and housing, but am not positive. I'm not set on using this thermostat if there are better options due to replacing all 3 components.
Also, the car was dyno-tuned with the stock thermostat, if that makes a difference.
Thanks for any help.
No doubt a LS2 thermostat & housing would have a better chance of working in a LS2 pump than probably anything else. Not sure that that's materially any better than the LS1 stuff, unless it got modernized over those few years. Also not sure about things like the pump outlet orientation, pulley depth, etc. Would require paying close attention.
Shouldn't interact with the tune in any manner way shape form or fashion as long as it remains "stock". That is, AFAIK the running temp for a stock LS2 is the same as a stock LS1.
My plan is to install without the thermostat and fill/drain a few times with distilled water until it drains clear, then install the thermostat, fill with Dex-Cool and keep an eye on it for the rest of the summer.
