5.3 problem SOLVED
Old Aug 6, 2024 | 09:02 PM
JackAsserson's Avatar
Originally Posted by the_merv
Don't know how you think you could do that, you hooked the Battery up backwards in your **** build and it doesn't run right...
Go troll somewhere else clown, you literally don't have the IQ to hang here.
No worries Merv, I’ve got several **** builds, some with the battery connected properly! If you behave on the way up to Arby’s, I may let you drive back. Starting to find that temper kind of cute . And you’re so smart
Old Aug 6, 2024 | 09:27 PM
I’m having a hard time believing Merv got so perturbed over a battery hooked up backwards and no fuses….in Internal Engine, no less. This is LS1Tech, where you’ve got thousands of terrible cam choices, thousands of incorrectly setup bearing installs, page after page after page of home-built hot-rod death traps, and I could go on and on about ridiculous posts contains zero technical info from guys with no business posting on a technical forum…heck a battery hooked up backwards is laughable to what I see on here everyday.
Anyhoo guys, cool it with the name calling and filth. You’ve both roasted each other enough for this go-around. Back on topic please.
Old Aug 6, 2024 | 09:32 PM
I guess I need to move this mess out of Internal engine…
Old Aug 6, 2024 | 09:37 PM
the_merv's Avatar
Well, thread posted in the wrong place tells you enough. We have some special people here.
Not sure what the topic is at this point. We've established bad wiring practice because hacked building, definitely some trolling in here because computer warrior that isn't **** in real life.
So what is the topic of this other than a hacked build..
Old Aug 6, 2024 | 09:45 PM
You’ve been moping around this forum for years calling someone a computer warrior. You’re probably typing from your mothers basement, bet she’s bitching at you constantly to get your **** boxes out of her garage
Old Aug 6, 2024 | 10:00 PM
the_merv's Avatar
Whole lot of words coming from some small pp energy simp that can't even hook up a Battery up right. Then again when your junk doesn't run that head will I guess.
Go get your **** fixed, get back to us when you actually do something productive. I've built more cars then you've seen, you have some catching up to do boy.
Old Aug 6, 2024 | 10:07 PM
Real photo of Merv in his mothers basement
Old Aug 6, 2024 | 10:09 PM
the_merv's Avatar
And still built more cars right than you have..
Old Aug 6, 2024 | 10:13 PM
With mommy or daddy’s money? I’m sure they’re real proud of their forum messiah self proclaimed hot rod master. Must be hard to type with those big ole hairy nuts in your mouth
Old Aug 6, 2024 | 10:56 PM
Get this JackAsserson outta here...... You don't need to insult people just because your complete lack of common sense was exposed.
Old Aug 6, 2024 | 11:02 PM
Hey look it’s Mervs husband
Old Aug 7, 2024 | 02:30 AM
  #32
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Enough.
