Holley oil pan for LS swap
Old Sep 2, 2024 | 08:27 PM
66OldsLS's Avatar
Default Holley oil pan for LS swap
So before I put the motor back into my car, I’ve considered the Holley oil pan. The oil pan I had before was the GM performance pan. It cleared the front crossmember fine aside from the sump would hang about 2 inches lower than the crossmember. Should I swap to a Holley oil pan? My car is a 1966 Olds 442 (early A body). The GM pan works fine but the concern of debris in the road or a high speed bump catches my conscious. If I do go to a Holley pan will the factory windage tray and pickup tube fit? Thank you.
Old Sep 2, 2024 | 08:31 PM
If you use the Holley pan you must use the Holley pickup as it reaches the correct distance to the pan bottom.
The windage tray will work but might need a bit of trimming.
Old Sep 2, 2024 | 09:46 PM
BOOT77's Avatar
What pan, Holley makes a few LS pans? What GM pan are you replacing?(IE truck, f-body, CTV, Corvette) That would also tell people what windage tray you have? I think the Holley pans come with the correct pick-up but not sure if all trays fit them, prob a good question for Holley.
Old Sep 2, 2024 | 10:13 PM
the_merv's Avatar
Veteran: Air Force
Yea there's 3 Holey Pans so need some clarification here..
Old Sep 3, 2024 | 05:55 AM
66OldsLS's Avatar
ah sorry, The GM LHA pan. Part number 12624621
Old Sep 3, 2024 | 07:30 AM
Old Buzzard's Avatar
Cheaper pans than the Holley......
(68) LS swap pan option | Chevy Tri Five Forum
