5.3 Build Suggestions
Old Nov 4, 2024 | 12:39 PM
LSpann's Avatar
Default 5.3 Build Suggestions
Hello forum im in the process of building a 99-06 Gen 3 5.3 Engine for street/strip. As for the bottom end all the bearings and piston rings have been replaced. The camshaft has been replaced with a Elgin SS2. Im in the process im deciding on the lifters. The lifters I removed look good except for one because the old camshaft I was using had a flat spot on the lobe. But I figure its not a good idea to reuse the lifters since I installed a brand new camshaft. Should I go with regular lifters or there any cheap well fair priced lifters I can swap it for extra hp or reliability?
Also what are you guys running for the oil pump? I ordered a replacement from ebay but it turned out to be made in china so I may not use it. I have the stock oil pump and its not seized. Can these oil pumps be rebuilt better or should I just buy name brand replacement?
Old Nov 4, 2024 | 04:44 PM
LS1Formulation's Avatar
Get genuine LS7 lifters. Brian Tooley Racing has them. Not the Delphi ones you see for sale everywhere. Do not run a Chinese oil pump. Buy a Melling 10295 and that's all you'll need.
Old Nov 9, 2024 | 03:40 PM
LSpann's Avatar
Can the push rods be reused or do I have to upgrade them?
Old Nov 9, 2024 | 10:00 PM
1FastBrick's Avatar
It would be best to check the length and see what size you need.
Their is no Guaranty the aftermarket cam has the same base circle as a stock cam profile.
As for an Oil pump, you can purchase an M295 Melling stock replacement pump through Summit Racing. https://www.summitracing.com/parts/sum-121170
For lifters, I would recommend the GM 12499225 at bare minimum with Genuine GM trays.
