Cooling system
Old Nov 20, 2024 | 12:53 PM
Flyinlo01's Avatar
Default Cooling system
Hello I posted on here the other day about oil and coolant issues on a re gasketed 5.3l. I've fixed the water in oil issues with another head gasket passenger side didn't seal. So now I've got a new gasket on and it has an external water leak now. But I accidentally broke off the nipple on the steam port, so I've got it blocked off. Will that build up enough pressure to cause external leak at the very front of cylinder. It's leaking right below the plug I've got in place.
Old Nov 20, 2024 | 05:35 PM
the_merv's Avatar
Get the replacement Steam Port piece, don't half *** it. It's there for a reason.
Old Nov 21, 2024 | 06:18 AM
EDS01SS's Avatar
Try some liquid teflon on the plug to see if that helps. A leak is a leak though and if the liquid teflon doesn't fix the leak then you have other issues there(crack, etc). The pressure is only going to be what the radiator cap allows and if the cap was bad then usually a hose would go before that plug leaked
Old Nov 21, 2024 | 06:43 AM
the_merv's Avatar
Did you not read his post? He broke the Steam Tube and instead of putting the correct part back on he's trying to bypass it.
There's the "other issues"..
There needs to be a reading comprehension test in this forum it's starting to degrade rapidly.
Old Nov 21, 2024 | 10:24 AM
EDS01SS's Avatar
read and misunderstood what he was talking about. excuse me oh great reader of readers
Old Nov 21, 2024 | 11:08 AM
the_merv's Avatar
Doesn't take much to read words, maybe my glasses are up to date.
