Best OEM replacement plug wires with headers
Old Jul 30, 2025 | 12:56 PM
goatmanls2's Avatar
Default Best OEM replacement plug wires with headers
Looking for the best OEM replacement plug wires that will not melt when close to aftermarket headers on my 6.0 LS
Old Jul 30, 2025 | 03:08 PM
Bbknucks's Avatar
Good luck. Almost all headers suck in comparison to factory manifolds in regards to plug clearance
Old Jul 30, 2025 | 03:19 PM
LS1 TJ's Avatar
I have on my 80 Camaro with Speed Engineering 1.75" long tube China made headers. I use stock GM wires but I always use the stock tin shields that goes on each spark plug but to prevent header tube the from touching the boot.
Old Jul 30, 2025 | 03:38 PM
Bbknucks's Avatar
I did a swap for someone and had same brand headers... some of the wires fit good but melted some others...this was in a b body.... ended up getting 45* ones with some of those little heat socks for em...so far so good
Old Jul 30, 2025 | 07:27 PM
DUSTYWS6's Avatar
I’ve always used MSD wires where you can bend the boot to help keep the wires away from the primaries. For good measure I’ve always used the fabric heat resistant boot covers. Never melted a wire.
Old Jul 31, 2025 | 09:47 AM
1988montecarloss's Avatar
i run the Taylor 45degree ones on my car but i do have a ziptie holding a few of the wires on the pass side where the primaries are wonky shaped
Old Aug 4, 2025 | 10:54 AM
99Silver6.0's Avatar
I run Hinson wires with 45° boots on both ends. They've been on my car with LT's since 2018.
