Fuel filter flow rate
Old Aug 23, 2025 | 12:52 PM
L672LS6V's Avatar
Default Fuel filter flow rate
I'm looking at a Motion Race Works dual outlet filter to supply rail and Nitrous fuel solenoid, I have a DW300 pump in the tank..there's different gal per min from 32 down to 6, should I just grab the highest or can I get like the 12 g/m one?
Old Aug 23, 2025 | 01:53 PM
If you know your max flow rate, get the one that will give you a comfortable margin.
Old Aug 23, 2025 | 02:15 PM
L672LS6V's Avatar
Makes sense, I kinda figured 12 gpm is in the middle and leaves room for growth (if ill ever need it) thanks for the reply
