LQ4 troubleshooting misfire
Old Nov 8, 2025 | 01:30 PM
Capp35's Avatar
Default LQ4 troubleshooting misfire
Just bought this car with a 2000 LQ4 6.0.
It had a lag/stumble on a fairly hard acceleration, and after a scan my knock sensors were apparently out. I replaced both, cleared codes, and reset ECU (battery disconnect).
Now I can feel it missing on low end acceleration.
Checked fuel pressure (not volume) and it was within specs.
Previous owner said he had a shop do a tune, change injectors, pump, and a coil, so at this point I have no idea what was installed. New owner of shop, with no records.
Any ideas where to start?
Thanks
Old Nov 8, 2025 | 03:56 PM
RB04Av's Avatar
If it has headers, start it up, and after 15 seconds or so of running, use your infrared temp gun to see if any tubes are cold.
Old Nov 9, 2025 | 06:17 PM
Capp35's Avatar
Thanks, will give that a shot.
Should let me know if a coil or injector is not working on a cylinder.
Old Nov 11, 2025 | 08:43 AM
Capp35's Avatar
Thank you so much for the suggestion.
Borrowed my friends temp gun and one of my cylinders was 200° cooler after 3 to 4 minutes of running.
I already had an order in for new plugs and wire, so I just added a new coil to the order. Hopefully that will take care of it.
Thanks again.
