LS6 Valley Cover New or Old??
Old Nov 30, 2025 | 01:12 PM
rcebrnr's Avatar
Default LS6 Valley Cover New or Old??
I'm trying to figure out if I have the newer 12577927 or older 12568002 LS6 valley cover. I've had it in storage for over 10 years. I need to know if I need an external PCV valve. I stuck a wire through the hose nipple and couldn't get past 1.75". Am I hitting the orifice which means I have the newer 12577927?
It's new and intake already installed so I don't want to remove to see if there is a part number anywhere. I've tried searching my emails for the original purchase but can't find anything
Old Nov 30, 2025 | 07:41 PM
LS1 TJ's Avatar
Total guess on my part but if the valley cover has a tube/nipple there is a pcv setup underneath?
Would take about 30 minutes to pull the intake/valley cover to double check?
Old Dec 1, 2025 | 07:43 AM
grinder11's Avatar
I agree. I have never seen a non-PCV cover with the nipple on it. They either have the nipple/PCV, or they're flat with nothing on the top. Either way, the factory PCV system sucks. If the intakes were made of cast iron they'd still never rust inside because they're full of oil....
