8 rib damper
Old Jan 2, 2026 | 05:21 PM
496blazer's Avatar
Default 8 rib damper
Can I run an 8 rib damper on my otherwise stock 2003 ZO6? I am building the engine on the stand now and will add a supercharger down the road. Would like to add the 8 rib Innovators West damper now if possible.
Old Jan 2, 2026 | 08:08 PM
HILROD's Avatar
It should work. The 8 rib I installed on a 01 I think was soo close to the steering rack. As long as the ribs are line
up it should be fine.
Old Jan 3, 2026 | 10:33 AM
Mr. Black's Avatar
Yes, any quality 8 rib should be fine on your C5.
I have and am using an Innovators West 8 rib on my C5 with a full 8 rib belt conversion. Plenty of room to the steering rack. Enough room you can change the belt without disassembling anything.
Whatever you do, do not buy the popular Summit Racing 8 rib unit. That thing is machined wrong and it lines up with no other 8 rib parts out there on earth.
