shift light hook up
Old Jul 29, 2004 | 02:35 PM
KAOS's Avatar
Default shift light hook up
i was told that you can tap into a wire under the passenger side of the dash. if so which one. or just run it out into the motor
Old Jul 29, 2004 | 03:06 PM
Tranzor's Avatar
there's a good write up on www.installuniversity.com
You need to tap into a wire at the PCM in the engine compartment, then run a wire through the firewall to the shiftlight, put your ground on a screw/bolt that's directly on a metal part of the car (there's a good one under the passenger side dash), and tap into an Acc. power source (I tapped into the power wire for the ASR switch).
