tb bypass issues
Old Aug 1, 2004 | 02:16 PM
slik98z's Avatar
Default tb bypass issues
i was told i coul duse about 2 ft of 5/16 rubber hose and clamps instead of the 15 dollar bmr kit for the throttle body by pass mod. seems like the 5/16 hose is too small for the radiator and too large for the T connection. if i clamp it tight enough to try to seal it, to me it looks like it will have a small hole for coolant to leak out. could i just plug this with rtv sealant? or what?
Thanks guys
Travis
Old Aug 1, 2004 | 03:56 PM
69_YENKO's Avatar
Thanks guys
Travis
I just used a 6 or 8 inch peice of copper tubing in place of the TB. i belive i used 3/8 copper line. it was a good fit on the larger hose on the radiator side. the smaller hose on the T connection side took some working to get it to slip over the tube it was a really tight fit. but it works great and has no leaks.
Old Aug 1, 2004 | 04:16 PM
slik98z's Avatar
i was wrong about the possiblity of leaking. the 5/16th inch hose and clamps worked perfectly. now if i could just figure out wahts wrong with my tb id be happy
