header install ???
Old Aug 3, 2004 | 03:36 PM
greenalien00's Avatar
Default header install ???
Is there a way to hook up hooker headers and their Y pipe without welding anythin? Can it just bolt up? If there is a way please let me know i am interested in doin so if possible.
Thanks in advance.
Old Aug 3, 2004 | 03:46 PM
SapphireHawk's Avatar
I am assuming the y-pipe slips over the header collectors and you just use band clamps to tighten them down.
Old Aug 3, 2004 | 07:08 PM
1RawTA's Avatar
im pretty sure the headers just bolt up... thats what most of the LS1 headers do
Old Aug 3, 2004 | 07:56 PM
Inspector12's Avatar
TT-TECH Veteran
They slide over the collector and the clamps they give you are not the best but better than a regular mufler clamp. I use the 3" stainless band clamps with a little high temp silicone for a leak free installation.
Old Aug 3, 2004 | 08:37 PM
bill99hawk's Avatar
Has your RTV melted away. I was thinking of trying this, but then read from others on here that is can screw up the O2s and will likely melt away.
Old Aug 3, 2004 | 09:17 PM
TT-TECH Veteran
Well mine has not melted away and so you know what I am using it says sensor safe etc... It is the permatex brand (red ) High temp silicone. It is after the front O2's any way and I am runnig an ORY so the rears aren't even and issues etc... Hope this helps.
Old Aug 3, 2004 | 09:35 PM
bill99hawk's Avatar
How long have you been running with the Permatex? I will likely try that out. I was also thinking that it shouldn't be a problem either because the O2s are before the band clamps for the headers.
Old Aug 3, 2004 | 10:25 PM
TT-TECH Veteran
It has been on my friends car for a long time mine was just finished a month or so ago though. actually longer but that is the amount of drive time anyways.
 Michael S. Palmer
