Help with header install!!!!
Old Aug 9, 2004 | 11:49 PM
Y2kforgedSS's Avatar
Exclamation Help with header install!!!!
OK so i got my new set of mac headers and y pipe so i take off the old y pipe and have trouble getting cats off. Im doing all this cause its a ory pipe and i want to change, but i have a walmart jack that gets my car off the ground about a foot then have cheap *** tools so i always break the sockets. How much should it cost to have the old ones taken out and the new ones put in? I dont want to do this by my self this time.
thanx josh brown
Old Aug 10, 2004 | 12:01 AM
2001 White Ws6's Avatar
Spray the cat bolts with penetrating lube. WD-40 or anything like that. Let it soak for a while and try it again. You can try a pipe and use that for more leverage onthe ratchet.
Get a better jack. If you are installing them yourself then want the car to be higher then a foot.
Old Aug 10, 2004 | 12:34 AM
ls1rocker's Avatar
for like 30 bones you can get a set of rhino ramps from walmart, those help alot, and a ratchet wrench, 10 mm i think will be your best friend for the header bolts, as for the cat bolts the penetrating oil is a good suggestion
Old Aug 10, 2004 | 01:11 AM
glennhl's Avatar
You need to get some better tools. I have a bunch of Craftsman tools I've collected over the years. However, I just got a set of Crecent brand tools from Costco for like $55. Came with just about everything you will need except you'll need to buy some more long 3/8" extensions.
Also, I pulled my CATS off seperately, but I read somewhere that you can take off the exhaust manifold and CAT as a unit. Just pull the Y pipe and then drop the exhaust manifold by taking out the 6 10mm bolts.
Old Aug 10, 2004 | 01:42 AM
Cool thanx alot guys and by the way i dont want yall to think im poor cause i dont have all the neccisary tools but if you look at my mod list thats were most of my moneys at and i usually have a better place to work on my car but i just thought i would do it at my house.
thanx josh brown
