Fan On, Engine Off
Any idea what they are set to and how to change them??
There must be another sensor to keep the fans on after the engine is turned off.
The fan is suppose to keep running until it gets below the cut off temp.
If your motor is 235 degrees.. why would you not want your fan to keep running?
You answered your own question.
My fans are set to turn on @ 180 when the engine is running.
Not when the engine is turned off. What I was wondering is can you can drop the turn on temp?
I would think there would be two sensors. Could the PCM use it if the engine is turned off?
