Header problem
Old Aug 12, 2004 | 11:53 AM
badaSS346's Avatar
Default Header problem
Has anyone ever herd of one of the headers coming pryed away form the head after the y-pipe smacks the ground?
Old Aug 12, 2004 | 11:55 AM
Keenov's Avatar
Did a header bolt come off? Did it bend? You left out some info.
Old Aug 12, 2004 | 12:01 PM
Keenov's Avatar
It is possible, if the car actually put enough weight on the y-pipe to push it up and bend the headers off of the motor.
Old Aug 12, 2004 | 12:28 PM
technical's Avatar
Sounds a bit violent, but I would suspect the primaries to either crack or break off the flange before ripping the bolts out of the head.
Old Aug 12, 2004 | 06:31 PM
badaSS346's Avatar
no nothing happened yet, but i was just curious since my ypipe has taken a beathing recently
