header bolt advice
Old Aug 17, 2004 | 10:28 AM
LoPeY's Avatar
Default header bolt advice
When I installed my headers, I also bought some Stage 8 Locking header bolts to put on. I've put almost all the bolts on, but have run into 2 problems. What is the best way to get the locking clips onto the bolts? I've already dropped and lost a few trying to get them on. My second problem lies in that a few of the Stage 8 bolts won't even start to thread on in some of the holes. Is there any logical explanation for this? My stock bolts all fit into the holes that the Stage 8 bolts won't. Any help is great as always. Thanks.
Old Aug 17, 2004 | 09:42 PM
LoPeY's Avatar
Nobody at all knows. Come on guys, I really need the advice on this one.
Old Aug 17, 2004 | 09:51 PM
99SSragtop's Avatar
sorry to say but re-use the stock bolts and don't force the stage 8's in cause you may cross thread them or the heads thread..If you really want to use the new bolts I recommend to re tap the holes your having problems with them put in the bolts.
Old Aug 17, 2004 | 09:55 PM
2002$$'s Avatar
or look at the end of the bolt....the end of the thread is probably all chewed up,orrr the very end thread doesnt come down far enough.try using a file to complete the thread.good luck!
Old Aug 18, 2004 | 10:57 AM
LoPeY's Avatar
I think I'll use some filing and retap the holes as well. That's a good idea. I have 9 or the 12 Stage 8 bolts already in. I just don't want my headers to walk out on me and burn up the gaskets. Any suggestions for getting the locking clips on?
