Help with windows
Old Aug 17, 2004 | 05:36 PM
Boostaholic's Avatar
Default Help with windows
I didn't get any response in the tuning / electronics section on this question.
This is driving me nuts, after my short block swap my pass side window won't work with either switch. I have gone as far as taking the switch out and I see 12v going to one of the pins (Brown one?) but thats it.
The window went up and down fine before the short block swap, should I just take my door apart and hard wire the motor to see if it works? Could the relay be bad? Is there a inline fuse or something?
Old Aug 17, 2004 | 07:42 PM
WILWAXU's Avatar
Probably a dead window motor. Very common problem.
Old Aug 17, 2004 | 08:54 PM
badpewter-z's Avatar
LS1TECH Sponsor
if you have swithched power at the switch its probbly the motor , they never give ya a warning
Old Aug 18, 2004 | 10:07 AM
Great, It just seemed odd that it happend RIGHT when I did my motor swap.
I guess its time to pull my door apart!
