Need info on location of sending units..
Old Aug 17, 2004 | 05:45 PM
tbojbob's Avatar
Default Need info on location of sending units..
Those of you that have non-stock electric guages, where are you putting your sending units for them? I have a two guage pillar pod and water temp and oil pressure gauges. Thanks for your help!
Old Aug 18, 2004 | 12:00 AM
Ferocity02's Avatar
Water temp goes in the block above the starter. The starter needs to be removed to get access to the plug. You will also need a M16x1.5 adapter. The other location is in the head by the #8 cylinder. Not easy to access.
Not sure about oil pressure. I think it goes somewhere around the filter, but search to make sure. And why do you need one anyways? You already have one
